Has S230 corrected EHD transfer problem? | SatelliteGuys.US
handymantoo
SatelliteGuys Guru
138
northeast
There was a reported problem of programs not transferring from EHD to Hopper and the programs lost. Has that problem been corrected? Is there a way to copy rather transfer a recording between Hopper and EHD?
In my tests you can transfer the same recordings multiple times without issue.
I succeeded with about 200GB worth of data that I transferred like this:
External Dev 2 --> Hopper --> External Dev 1.
Previously transfers from either External drive resulted in an unplayable file.
Works for me, I don't know if anyone else has chimed in.
The only problem I have with 230 software is that my hopper doesn't see my external hard drive every morning. So I have to uplug and replug it back in before I can use it.
THis was happening on S222 for me as well. I don't remember back before S222 to tell you if it has been out there longer than that.
Sent from my ASUS Transformer Pad TF700T using Tapatalk HD
Not sure about the transfer issues (never had any personally) but it definitely seems to have fixed the bug in the EHD menu where not all of your recordings would show up until a reboot
Sent from my iPhone 4S using SatelliteGuys
DishChannelChart Down?
Dish Network FlexTV Questions..
