Hava Player App | SatelliteGuys.US
Hava Player App
I have it for the iPhone. I am still waiting for them to enable 3G streaming and create an iPad version. I think the company is pretty much toast which is why they have not updated their app in about 2 years
OK...This is weird
The Hava box even through Vulkano is not supported over 3G. When I use it on my phone I get the message that Hava is not supported over 3G. But when I use the same phone as a WiFi hotspot using 3G I can get other devices to play it on WiFi through my phones 3G.
Android now has a vlc/remote app out
wonder if we could stream our hava's now
to our android device's using 3g.
testube works fine with wifi , but I get freezing, constantly using 3G
remotely
I know this is an old thread, but is it possible to get an "old" vulkano flow back up and running?
I installed the box, and found some HAVA Windows software which should have been able to set up the Vulkano. After a few deadly Bluescreens, the software eventually started, but said I have a HAVA Gold and that I should insrall other software (which I can't find anywhere). In the end, I don't even have a HAVA, but a Vulkano.
On the website of Monsoon, I can manage to download a users manual, but downloading the software rails.
Then I Remembered
Then I remembered the name I gave the box, and found an Android APK. But, that app either states that the service is unavailable, or that I need the paid version of the app (which isn't available in the Play Store anymore).
Anyone have any ideas?
