Having trouble w/ playback of events from one OTA station. | SatelliteGuys.US
whatchel1
9,098
51
Great High Plains
Seems like every night lately that I record off one OTA channel. It's coming in very strong but when I play back and either FF or use the skip that it just half way through and then will end with it well before the end of the show. So I wind up loosing most of the program. It is a Fox TV station and seems to be only that one station. I can't skip damn commercials. Really PO'ing me. I have a 722k w/ the OTA module. I just wanted to see if others are having similar problems before I contact DIRT for a replacement.
I don't have this issue around here on my 722. Perhaps Fox has screwed up the metadata in their transmission and this is confusing your receiver. Or your hard drive is going south. Are the other good recordings also OTA, or rather off satellite? The greatest bandwidth being requested of your disk for a single stream will be OTA HD stations. If you are comparing Fox to a satellite program, it will not stress the receiver as much.
OTA module troubles
MyDISH.COM Down?
