Hbo? | SatelliteGuys.US
Hbo?
dingman
4
Is it possible to have HBO with a coolsat hd 8000 - what would i need to buy other than the coolsat?
Thank you for your response. What is the purpose of a coolsat 8000? What can I do with it?
I know this thread is about HBO, but based on your previous post, maybe this info will help...
Here is are a couple of good lists on what you might expect to receive using an FTA receiver legally.
At least on Ku band (3' dish)
FTAlist
Global-CM
As for hi def, I think PBS makes up the bulk of what's available.
Hunting "feeds", may get you some special events, field news reporting, sporting events...
Unless you are interested in C-band satellites (the 8..10 foot dishes), that's about it.
Thank you for all of the helpful info - I'm sure I will be back with more questions after I research a bit - Thanks again!
HBO is normally a digicipher 2 (motorola) signal and cannot be seen with a FTA receiver even if it was in the clear.
You need a c-band 8' dish or larger with a dsr-922 and a subscriptions through a program provider.
Conaxsat V1 Setup
Cloning a Receiver
