HD output problem | SatelliteGuys.US
HD output problem
rickc
56
Here's one for the experts out there.
I have a 722k hooked up to a Pioneer PDP 5050HD via HDMI.
My problem is this:
On any HD channel my TV shows "Partial Zoom", and I do not get full screen HD.
The TV is set to auto detect via the HDMI connection, and the 722k is set to 1080i.
Is my problem with the TV or the 722k??:confused:
Thanks for any insight.
My problem is this:
On your remote, press the Format button, just to the left of 0 and under 7, until you see Normal. You're all set.
Hey! Thanks much!! Yep, that was the problem. I had read the manual, but had not seen the reference to the format key on the remote. :( Had been living with the partial stretch for some time, and am very happy to have my full screen HD back.:)
Hope to return the favor someday!!
Can you change the billing date? No!
Dish 500 locked on 119 & 129
