If it can do 4:2:2 also (which isnt in the specs or yet to be proven) then that is great. If it can do blind scan but not 4:2:2 its no better than a Pansat 9200
Ice,I want PROOF!
no not reallyIce,
Would you be surprised that I agree with you on that?![]()
but the issue is dvbworld said yes it has blindscan as noted in posts 4 & 6 but yet hasnt shown it. So saying it has blind scan but not showing it gives me doubtsBlindscan Menu Screen should definitely be shown, if finalized at that time in firmware. :up
I'm not worried about the PVR...others may be but I'm not. I want it to do blind scan (DVB for sure...DVB-S2 would be a plus) and to do 4:2:2 yet we have not had confirmation that it does either other than him saying "yes it does".It may not be the case however, which doesn't mean much if its added in a short run. DVB World already said, its supported by the chipset, and the STB Processor and MoBo are powerful enough to handle heavy load without overheating. I tend to trust that since he's a pro, if you know more about him. In fact, he said: "Please guys give me the files, I want to fix these features for you as soon as I can since I want SALES, but I don't have these super signals around, and it makes me crazy!"Did he said that?
He needs samples and...some time to work with them.
its pre-ordered. I had a CS8000 preordered before they were availableBTW, it may look too soon to start taking orders on this box, we don't know much about from local testers.
sadoun said:As far as this model is concerned:
* No 4:2:2 out of the box
* No hardware Blind Search. Only NIT and Auto Search
* No internal hard-drive included with receiver. You can connect an optional external HD or Flash Memory through USB.
* E-SATA support is not verified yet, but I suspect it is available. I will check on this for you.
I canceled too.I will be PM'ing or calling Sadoun and cancelling my order.
Sorry for your disappointment Ice.
This is the lowest power consumption of any STB I have ever heard of. Nothing I know of even comes close. There must be cutting-edge technology inside.our stb works is very excellent, it works power max 10W, so it work very cool.
Language is an issue. When I visit factories in Asia and talk to development engineers, I have a hard time sometimes getting "our" terminology explained to them. Many think Auto Scan or NIT scan IS Blind Search.
Limited time offer
