So 72.7 seems to be OKI am on WA with a swing dish to 61.5, using coaxial cables, 622 and software L635.
Now watching HBOCY on both TVs, no problems here. Yes, my HBO HD channels are on 72 sat. My HBO SD channels report 61.5Currently watching HBOCY HD on my TV2, Eastern Arc, TV1 is off which is normally connected by HDMI.
I have an old 27" CRT HD tv, so I'm sure it's not HDCP compliant. I will turn everything off, tune TV1 to HBOCY, and see if my TV2 coax connection has any problems.
Oh, that gives me another scenario to try when I get home today. My modulator settings have TV2 coax out on antenna channel 60 and TV1 out on antenna channel 69. I can tune my living room HDMI TV1 to HBOCY and see if the coax feed over channel 69 is still available. That way I don't have to change my settings to single mode to test it.I used to have this problem with a TWC box... It wasn't true 2xTV, but when I was single, I ran the coax output upstairs, and was thus able to use the same single DVR to serve 2 TVs... BUT I had to use component downstairs, b/c if the box detected HDMI with TV1 off, it would not feed the coax.
I am getting the HDCP message on all HBO channels. I have a 622 ver L635 connected via HDMI to a brand new Mitsu 73738. WTF!!!!! Been getting this message when trying to rent a video and just overlooked the issue, but now that I can't get HBO....... They are all shooting themselves in the foot with this BS. Guess I will have to investigate alternative programming providers. Anyone know if DirecTV is having these issues also?
Any devices installed betwixt the receiver and the Mits (AVR, video processor, 3D adapter).Says Digital = yes, HDCP = No.. And I know this Mitsu has HDCP.
Just to point out .. you don't mean to insinuate that the OP (la_due66 in this case) is *not* in-compliant, but that there could be something wrong with the setup that is causing this problem and the user should get dish chat or call into dish to get some help ... right?I'm on Direct and just checked all the HBO channels. I get no indication of HDCP issues. But I may be in compliance and it wouldn't show up.
Limited time offer
