Are we even sure it has made it to this channel? Something has delayed it apparently does anyone know when or if it is likely to happen?
This suggests the analog "hole" is still available.Well I am connected by component cable and I have not missed anything yet.
This suggests the analog "hole" is still available.![]()
Just went and tested it on my non HD tv that is hooked up to my 622 via coax cable and it tells me that I cannot watch this channel. So it does look like it has been rolled out already.
I guess it could be that any 480i output is disabled but I have to admit I have not been clear on how this is implemented.
So why am i able to watch it on an HD set when hooked up by component cables? Is it that SD outputs are disabled but not the HD ones?
Are you on the WA?
Geronimo said:Negative. Are you suggesting it is activated on one arc and not the other? Makes more sense than anything else I have heard.
Limited time offer
