hddvr 24 wireless hook up to internet | SatelliteGuys.US
prop
91
7
mexico
i guess i need a wireless video bridge or something similar?i am not using a swm just 2 wires into the ird.what do i need? thanks for any help
Although I would advise you to use rad's link to Solid Signal for illustration only. And look on ebay for deals of actual purchase at a much lower cost.
I like third party sellers such as S.S. or Weaknees, but they're just too darn expensive in most cases.
Sent from my LM-V405 using Tapatalk
I'm using a PowerLine adapter on one of mine. You can also use a RJ45 to Wifi bridge.
Once you connect the Ethernet you need to reboot the receiver for it to detect it.
Reactions: Jimbo
... You can also use a RJ45 to Wifi bridge.
Although the DCCK-W can also be used as an RJ45 ethernet to WiFi adapter.
You don't have to use MoCA coax to WiFi.
Plus I think the DCCK-W would actually be better in that role since the firmware on the HR24 will automatically detect the DCCK-W and display its setup and configuration screen on the TV set.
Genie2 in rv
MLB Extra Innings
