HDMI/HDCP problem | Page 2 | SatelliteGuys.US
HDMI/HDCP problem
The 722 has a setting that selects your TV/Projector by brand and model. Is that set up correctly? Same thing would be to adjust the output (720p/1080i) to match your projector.
which menu is this? i have not seen it.
bruce
If calibrated properly you will see no difference between HDMI and component.
You will see a softer picture, i.e. less fine detail, as there are additional domain changes.
To come out component, the Receiver has to do a D/A conversion. At the projector, there has to be an A/D conversion followed by internal processing
With a full digital path, there's just the straight line with processing.
Most people with "normal" sized TVs probably won't notice it, but those of us with larger front projection systems see just about everything.
Santa Barbara HD Locals Uplinked, Now What?
New smart cards for dish net receivers
