HDMI question | SatelliteGuys.US
HDMI question
xyz38
163
51
Eastern NC
I have just bought a 55" Samsung 4K Qled TV Mod Q70 series to replace a Sharp 52" TV that is over 10.5 years old and still has a great picture.
My question is for the posters that have upgraded to 4K and replaced their HDMI cables with cables labeled 4K.
Does the 4K labeled cables make a difference over the old HDMI cables?
Used with Dish Hopper3 and Blueray player
To watch UHD content (aka 4K, which is not a correct description), you need HDMI 2.0 or better cables. On the Hopper3, that means the UHD channel, UHD On Demand, and Netflix UHD, otherwise, you'll be stuck at 1080p at best. This is also true if you have a UHD Blu-Ray player.
If they work you're fine. If no picture, you'll need new cables. Don't get suckered a pay a bundle for them or pay much attention to "certified" labeling. Any Chinese company can print that on their product. They cheat you know? $10 - $15 at Amazon will to do it.
If it came with HDMI 2.x, the installer must have kept them. I need long cables, 8 to 10 feet, and it probably did not come with cables that long.
Upgrade Advice
RC73 (two of them) failing on HR44 after one worked before
