I won't recommend a TV, but I will tell you that if you read the other 1000 posts about HDMI cables found on these boards, you'll see that the only difference between the higher-priced cables and the lower-priced ones is exactly that: the price.
ps: $17 is about $15 too much to spend. Check monoprice.com or even Amazon.com for a better deal on cables.
