Help! Aiming Superdish (121) | SatelliteGuys.US
martinv
2
Moorhead, Minnesota
I'm moving my dish to avoid a big tree that is growing in its path.
I get 110 fine on the 110 LNB using port 1 on the switch,
The manual then says to plug the FSS LNB (121W) into the switch port 1. I can't get any signal at all.
I tried the recommended transponders (15,16,20,21)
I'm new to this so it may be a simple mistake.
Most of my channels are on the 110 and 119 sattelites. I also tried aiming 119 and again NO sigal. It's as though the 110/119 dual LNB died.
Also, why when I switch to sat 129 I pickup signal from 110? The screen says:
"Not Locked - EchoStar 110 West."
Is 1 tree enough to destroy a satellite signal?
Space Systems/Loral Delivers EchoStar XV
There is no need to contact us, we are trying to restore..
