I have been a Dish Network customer for many years. I was Primestar customer before that. My dish has always been in the same place which is on a pole in the front yard. This spring, I stated to have signal problems. In the past my signal had always been 100+ on 110 & 119. Now 110 is still decent at 105 but 119 has dropped to just above 60.
I recently upgraded my 721 to a 625 receiver. When the technician came out, he checked the dish alignment at the pole with a meter and said that a neighbors tree was starting to block my signal. He tried adding an extension to the pole, but that did not seem to help. As long as there is no wind and no rain, I have a good picture with only occasional distortion, but if it gets windy or rainy, I quickly loose signal. It would be difficult to re-locate the antenna. It was placed there originally because it was the best location in the yard. The pole is set in concrete and the cables are buried underground. Would a larger dish help? If so, what kind and where could I get it?
Thanks for any assistance you can give.
