Help - No OTA Channels | SatelliteGuys.US
Saphite
14
For the last couple of days, on one box (I have two), I haven't gotten any OTA channels(2,4,5,7,9,11). I know that it's not a sattelite/antenna problem because the other box is working just fine. I have rebooted about 5 times and still am only getting channels 100 and above.
Any ideas?
I assume it was working before on both. Can you swap the receivers? At least it will tell you whether you OTA module went bad.
Ok...now they both work fine again...OTA's on each after swap.
How'd you do that Sean?? :)
May be the tuner module, or one of the connections didn't have a good contact?
I haven't moved it since I got it. I never looked at the back of the box, so I didn't even realize there were 2 seperate wires for satellite and OTA.
I'M A NEWB!!! :no
Thanks for the heads up.
Just ordered VOOM in San Francisco
Voom service call today
