Make sure you connect to the multiswitch input labeled LNB-2 or SAT-2, not to the second outputMartin586 said:Great - a picture is truly worth a thousand words. So all I have to do is get a short piece of coax and connect the second exposed outlet on my dual LNB to my multiplier. Do I plug it into any available input on my multiplier?
Not really. The second connection will only be used for those few channels.Was also wondering if I may benefit from a better signal strength as a result of both lines plugged in. Are there other benefits of doing that?
There shouldn't be any exposed connections outside the house and all connections should be sealed (made waterproof). Otherwise, you will experience rain-fade and other problems very soon! Sounds like your installer didn't do it right.Martin586 said:Great! You're really terrific! I was wondering why there was an exposed outlet left on my multiswitch, collecting rain and rusting away. And all this time it should have been connected to LNB-2. Hopefully the outlet is still usable.
They should've been visiting this forum more frequently!It is amazing that at least 10 individuals at Voom could not figure out the problem (including technical support, 2 techs and more) and you did!
Net problem! I help people for fun, not for profitSpasiba !!!!!! I'm a clinical pharmacist in NYC and if you ever need a pharmaceutical/medical advice - feel free to call on me
It's not necesserily damaged - give it a try. FYI, the second input might be labeled as "18V SAT" - that's what you need.Martin586 said:Or would it be better to purchase a new multiplexer at radio Shack - since this one may already be damaged? Can this multiplexer be purchased locally?
Then make sure that the multiswitch passes DC voltage to the antenna input. It should be indicated on the diagram. (If you have a voltmeter you can check the voltage at the antenna connection: should be 12-18 Volts). If your installer installed a wrong type of multiswitch: the one that doesn't pass voltage to the OTA input (and I wouldn't be very surprised now ), then the OTA amplifier within the antenna may not work. That would explain your OTA problems...Martin586 said:I believe it is an amplified antenna.
Limited time offer
