help please on lnb | SatelliteGuys.US
help please on lnb
wildcat374
29
2
North carolina morganton
not good. hooked up my ASC1 and hooked my Polarity Servo motor up and as soon as i flpped on the power no the ASC1 lost all quality i had to set both polarity at +20 and my quality came back a little do i need to leave it on 45 default and tune my dish on ? . this is driving crazy.
Your feed horn may not be aligned properly in the holder.
Also could be a bad polar rotor.
Put it back on 45 and then go out to your dish and twist the feed horn till you quality returns.
Now check to see if Hoz. and Vert. transponders are coming in like they should be.
Reactions: Titanium
Newbie that needs help
wanted used or new tek2000 6ft dish, 7ft discountinued, or 8ft
