Help with cabin dish | Page 2 | SatelliteGuys.US
satellite drift does not alert the audit team and is no indication of fraud, i know of several people, including my self who use multible antennas per household becuase they are cheaper then multi switchs and look better than wrapping the house with rg6
Don't you have to manually enable DishComm to use it?
it appears on at all times, that is it transmits to any box who happens to be able to hear it.
e user manual specifically instructs to find all boxes including other subs.
so it could report a box where it doesnt belong.
run a check switch with no cable attached from the dish....that will clear out the matrix,,when it says "you have fewer sats" say YES
Then hook up cable and rerun check switch
Thanks that did the trick. Worked like a champ. Thanks for all your help.:)
Receiver Volume levels
