Help with FTA circuit | SatelliteGuys.US
Fai
Hi:
This is my first attempt at connection; hope I am doing it right.
I have a Uniden 590 receiver and a DMT-2050NTSC receiver, a C Band antenna/LNB and just installed a dedicated KU Band antenna. The later is fixed.
Skyvision sent a hook up diagram for two splitters and a DiSEqC switch with the digital receiver.
I intend to use the analog receiver to position the antenna and to continue to receive analog signals on various satellites on C Band and the digital receiver for reception on the C Band and KU Band on a single satellite at present. I may add a positioner on the receiver at a later date.
Will this set up work for me?
C BAND SPLITTER 1 C BAND
LNB REC.
KU BAND SPLITTER 2 DiSEqC MPEG-2
LNB SWITCH REC.
Splitter 1 to analog receiver in and "A" in on switch. Splitter 2 to "B" in
on DiSEqC switch.
Thanks for your help of this neophite !
Carl ("Fai")
Maybe easier to connect the C-Band receiver to the Loop-Output of the Digital receiver and connect the C and KU dishes to the switch.
The C-band LNBF would would need to be a newer model with 15-16V Polarity switching.
I may have missed something. Somebody help me.:)
Twinhan 1020a Help... can't lock a transponder
Motor movement issue
