Help with Satellite placement | SatelliteGuys.US
umrebelfan
5
Mississippi
Hello,
I have DirectTV (through my AT&T) coming Saturday to install. Problem is that my landlord says I cannot attach anything to the house. What do I do??? Thanks
:welcome to Satelliteguys umrebelfan!
You may be SOL if your landlord doesn't want a dish attached to the house, but the installer may be able to mount to a pole in the ground. Would that be acceptable to your landlord?
Some are prepared for a pole install, but it's prudent to let them know your situation.
A pole mount is "NOT FREE" about $75 you can work with the installer on that - also HE does need a clear line of sight and to bury the wire if needed the first 20' is free and longer than that it's a dollar a foot - but you can ask him not to do it and just leave it for you to do -latter.
Pole installs are sometimes free, it depends upon the installer and whether or not there is any other options to install the dish.
Reactions: stardust3
This is questionable, as many would rather place a pole than lose the job, seeing they get paid by the job ...
Often times it is free.
Genie 2 factory reset
ESPN app not loading
