help | SatelliteGuys.US
help
Jackfish
16
Hi all
Ok frist here is what i am working with
p4 2.4
xp sp2
786rm
ait 7500 64mb
VisionPlus 1020A
ok get lots of strength with 0 quality
have tried the walk thoughts was useing . ProgDVB
man any help would be great
30 in dish
Galaxy 11
have two lnb using one at a time
1 dss lnb
2 StarChoice round type lnb
used Sat finder
no switch
Your LO setting might be off, as Cascade was saying. If you are using the DSS lnb trying to get Galaxy 11, you will not get anything. You can try one of the dbs sats just to make sure your setup is working.
AMC-15 Launch on Ku and C
Manual entries on 3618
