HH90 and Winegard 76CM | SatelliteGuys.US
loyd
8
Hello to everyone, I first would like to appologise is this is in any of the FAQ's. I lookeed all over and cant seem to find the solution. I recently purchased a Winegard 76cm with a STAB HH90 to hookup to my Captiveworks CW600. I've live in Kanata Ontario Canada and have the following values for my USALS installation
Logitude=75.8533
Latitude = 45.3031
I've set the STAB latitude to 45. My calculation for my dish angle is 37.8. The problem I'm having is I cant move the dish because the bolt for the LNB arm is hitting the shaft from the motor. Has anyone seen this and if so, what was the solution?
Thanks in advance,
Loyd
Make sure you are using the RED line to set the Dish elevation.....
The best I can get is 22 (with the red line) before the LNB arm bolt hits the rotor pole. I can go up to the roof and post pictures if that would help
The HH90 is not compatible with a Winegard DS2076. The design of the dish mount does not allow for setting the correct elevation.
You will need to replace either the dish or the motor with different model. Unfortunately your dealer must not be aware of this conflict.
I bought the "turn key" dish lnb and motor together. What is the recommended motor to work with this dish? I'm supprised that the dealer didnt know about this as they are fairly large. Out of all due respect, I wont mention their name as they are one of the sponsor of this site.
I use GENUINE Moteck SG2100 with all Winegard DS2076 motorized setups!
Sound, But No Picture
Pas 9 58W-British Telecom
