I was celebrating too soon. I just found out on 97W Galaxy 19, all Horizon frequency were fine but no signals on any Vertical frequencies.
Michael,Because USALS is exact based on a calculation from your Long. and lat. It does not allow for user changes.
Many STBs reissue switch and motor commands if the signal is lost, while changing channels or entering/changing menus. The STB is programmed to establish a signal path and issues the saved data.If the menu provides the single step/stop and continuous move/stop, then why the motor jumped back without my input command?
No, not the way satellite signals work.Ti,
Good point and I will double check, but I have a feeling that one will get weak H channels if elevation is off, and weak V channel when azimuth is off.
Limited time offer
