Hopper 3 dvr question | SatelliteGuys.US
Mandeville985
22
4
Mandeville, La
my daughter had a bunch of shows set to record s trying to set them back up. My question is there a way to type in the series name and setup a series recording if the show is not on right now? Or do I need to wait for the season to start and just set it up through the guide? 2 of her shows are in season and setting them up were easy. The guide recognizes her other show names through a search but having trouble telling the hopper 3 to record them when no upcoming episodes are listed
Ok from a Google search I found the info from another post on this site... So was able to plan the timers, it's currently listing the show name, new and reruns, and seek. As of now is there a way to edit the seek timers to only record new episodes?
I can't answer you're question directly, but as a brand new Dish customer myself, I've found the iPad app to be very helpful in setting up recordings. There is a way to do what you're asking on it, along with a search feature. Honestly, because it's so easy, I really haven't messed with using the remote to set recordings. Hope this helps....
I've found that some searches offer a "record when available" option for programs that are not scheduled to air yet, but are apparently in the system somewhere....
When the show with a seek timer shows up in the guide, it will become a DVR timer and you can edit.
OTA Reception issue with H3
Direct Hopper access to WatchESPN
