Hopper 3 reset timer? | SatelliteGuys.US
oldford
432
6
Eastern Maine
My Hopper 3 resets at random times almost daily. Changing the timer value seems to change the time of day that the reset occurs, but it doesn't follow the setting. For instance, I had the timer set for 0100 hrs and the reset was happening between 0600 and 1000. So I change the timer to 0400, now the reset happens at 1700 -1800. I would like the reset to actually occur between 0100 and 0500, so as to not happen when I could be watching. This has been going on for quite a while. Is my Hopper broken?
Best regards, Eric
Reactions: LQQK
Mine started doing this after the last upgrade. Recordings longer than an hour (e.g., a sports event) are frequently broken into pieces.
How do I transfer timers to a new Hopper 3?
Dish.com not working?
