Hopper 3 Software Version H312 40.0 Remote Control Color Button Menu Shortcut List | SatelliteGuys.US
charlesrshell
SatelliteGuys Crazy
11,247
5,979
O'Fallon, IL
Attached is the latest 40.0 remote control color button menu shortcut list dated 1 Dec 2021. Did not find any color button changes due to the Hopper 3 software version H312 update.
If anyone discovers a mistake, find any more changes, or have any suggestions for the list please post them or send me a PM and I will update the list and post again.
Reactions: TheKrell
Would you consider making a diamond button menu for the 54? I discovered last night, after using my J3 for years, that the one-diamond button on the left is the same as the record button on the 40. The 3-diamond button (actually it's 2-diamonds) on the right toggles closed captioning. I have no idea what the center button does.
Reactions: charlesrshell
Would you consider making a diamond button menu for the 54? I discovered last night, after using my J3 for years, that the one-diamond button on the left is the same as the record button on the 40. The 3-diamond button on the right toggles closed captioning. I have no idea what the center button does.
Those are customizable, so there is no point in making a list. Hold one of the buttons down and you can change what it does.
The center button is the number 0. Use it for inputting a channel number.
Reactions: TheKrell
Joey 4 and Hopper Plus pictures!
Upgrade Hopper 3 Using DPH 42 Update.
