Well, if the problem lies in the equipment/wiring from the dish to the Hopper, then all joeys would experience it as well.I wouldn't think it would affect every TV.
What would that prove? Component cables are restricted to 1080i and no HDCP.Have you actually tried Component cables? Results if so?
Dan
If the Joeys looked fine, I would suspect the HDMI input of the TV. It cannot be an LNB, it cannot be a fitting, it cannot be a coaxial cable, it cannot be an HDMI cable. Its either 2 bad H3s in a row or the Bermuda Triangle. Everything leads to a bad TV (or HDMI input of the TV) but the bad pictures on the Joeys knocks that out. I am flat stumped (and I have the 55EF9500)
As I said, everything points to a bad handshake of the HDMI EXCEPT that his Joeys are also suffering from poor picture. That's a mighty big exception.Component does support 1080P wherever you read that it does not is wrong.
Connecting by component could certainly tell us something. If picture is what it is supposed to be that narrows it to the HDMI connection from the receiver to the TV, and even a stronger reason to believe it is a handshake issue. Trying the receiver on another TV also would give some insight.
This may not be unrelated to the Hopper 3 causing an apparent false HDR on some reported OLED LG tvs.
Dan
If he doesn't want to try component that is certainly his call. You don't know what is wrong (nor do I) so not trying something makes no sense. Far far more seemingly unrelated things have turned out to be related, but hey...Has he tried the joeys with the Hopper 3 not connected to his TV?
Also don't have a USB thumb drive inserted in the TV.
After reading all this, it does appear to be a HDCP handshaking issue. You said everything was the same except for the Hopper and the LNB, but a big difference is no more AVR in the middle, which that receiver may have been doing the proper handshake with your old Hopper for the signal to the TV. Perhaps the TV has no problem handshaking on 4K content but is having an issue with HD. You say the AVR can't handle the Hopper3 4K signal, but could you at least hook it up temporarily to see if the AVR solves the HD problem?
Since I posted, I know longer believe it's a handshaking issue, but something to do with the LNB or node or wiring, since it is occurring on every TV.Agree, well put. Its what I have been trying to say.
How does the USB Drive effect my other inputs?
I hope he knows the difference between component and composite connections.
Dan
I was the techs and he said maybe the first person here in Cincinnati to get the Hopper 3 yesterday morning. Love the new remote and new ui. Here is my issue. On every channel and vod, the HD quality is horrible. I messed with me picture calibration a million times and got it looking reasonable, but compares to almost DVD quality. I am a techy and work in IT so yes I have made sure it is set to 4k,1080p, 1080i and tired others. Also the 4k Joey is the same on my other TV. Something just isnt right. I'm beginning to think there is something weird if you don't actually have a 4k set yet. Anybody have any insight?
Your first point - it really has nothing to do whether it's a 1080P or 4K TV.
As far as your LG turning on HDR mode, that's a TV problem. The video must contain the HDR metadata header for a 4K HDR set to switch to that mode. There is no such header output by the H3. I would try a different HDMI input for you H3.
Gerry
PS: To the OP- as mentioned above, all wiring needs to be checked that it was done correctly. If it is then your H3 probably has a video problem internally. Did you do a pull the plug reset?
Limited time offer
