you're at 212? menu > settings > diagnostics > updates > inactivity stand-by > disabled. or are you refering to be able to select the hour the receiver will take the updates?
Thanks, that is exactly what I needed. There menu placement is pretty illogical in my opinion. And I really would like to also change the nightly update time as well.
