Hopper HWS "Known Problem" | SatelliteGuys.US
mrlasvegas
33
Los Angeles, City of
Anyone else have this problem?
Had HWS installed 3 weeks ago and been having this problem since day one. Dish says it is a know problem and are working on a fix. I was initially told it would be fixed Dec 4th but it wasn't now they cannot tell me when a fix will be completed.
My recorded shows are all assigned to a folder, when recorded they go in the folder and everything is fine. after a program is watched and deleted, ALL programs in ALL folders go in to the deleted folder within each folder.
I've never seen that issue and I tried to reproduce it just now and wasn't able to. Unless someone else can say they are seeing this as well, it sounds like maybe an issue with your receiver. If you use the Folder by Title and watch and then delete 1 event from that folder does the same thing happen?
it not only does it with the folder the program is in but all folder programs go into the deleted program folder within that folder.
I figured it was a receiver issue but dish says they are aware of the problem so I am holding tight for a fix. I was just wondering if it is happening to others
So all your events appear to be in the deleted bin? What software version do you have? I know that I heard that there is a known issue regarding DVR recordings missing or something along those lines but this doesn't sound like that known problem.
And for clarification, do the recordings STAY in the deleted folder even after you exit out of the DVR screen? Where you then have to 'undelete' them when you go back into the recordings list?
I have experienced the weird icon issue only on a few occasions. Where you are deleting a recording then all of a sudden the icons start to disappear, line-by-line as you scroll up or down. But they always return once I exit the recordings screen and go back in.
If like my issue then I can understand how they say it's a known issue. But moving all recordings to the deleted folder is very odd.
Posted Via The SatelliteGuys Reader App!
I think if you deleted the last item from the last row that it would scroll up some of the rows without filling in.
And yes if you back out and reenter that menu, it will re-populate all rows. You can lose nearly all rows.
-Ken (From memory worth the paper it's written on.)
Remote Control Color Button List
HWS- Disable Wireless
