Hopper remote interference | SatelliteGuys.US
dlharm
1,038
67
So. Central Nebraska
I did not find much on this online --so I am posting it on here. There are two minor issues I have with the hopper/joey.
1st--I'm getting interference from another remote as the joey in the kitchen keeps getting turned on-therefore using one tuner. T think it is from the remote in the room with the hopper--the tv's are around 15-20 foot apart. I've tried moving the antenna around on the hopper-did not seem to help.
2nd--The kitchen tv, an LED, is an obscure brand (QTV--Quantum) and I can not find a remote code for it. Is there such an item as a generic code to try or do I just live with it the way it is. I suppose I could make the joey remote learn if it comes to that.
Any suggestions on one or both of the issues will be appreciated.
I've asked that this be moved to the hopper zone.
IR was enabled on the joey--I disabled it and I'll see what happens after doing that.
I don't have HDMI-CEC as of this time.
Thanks! for the suggestions.
I would un-pair all remotes (press menu twice for info) then pair again making sure the pairing screen is not showing on more than one TV at the same time.
Autohop only working on two network channels?
NickMom??
