How do I remove done/deleted timers | SatelliteGuys.US
spec1alk
57
2
I have a Vip722.
If I look at the "Daily Schedule" from the menu, how can I remove the old deleted/completed timers from the list on the left? If I can't remove them, how long do they stay around?
DELETING DVR RECORDED EVENTS
Access the DVR Events menu.
NOTE: DVR Events can be accessed one of two ways:
Press the DVR or PVR button on the remote.
Press the Menu button on the remote
Select My Recordings for models: 501, 508
Select DISH on Demand then My Recordings for models: 510 and 612
Select Preferences then My Recordings for models: 522, 622, 625, 722, and 942
Select TV Listing then DVR Lists for models: 721 and 921
Once on DVR Events menu, Highlight and select the event to be deleted.
Highlight and select Erase or Delete.
Select Yes on the pop up screen that confirms the deleting of the event. Note: If the receiver is locked, it will prompt to enter the password.
I assume you mean the entries for things you have already watched and deleted. No they cannot be removed manually. I think they remain for a week. One purpose is to prevent duplicate re-recordings of things you have just watched.
Dish Network 322 with Winegard DS2076
Dish network® meets 100 hd channel mark ahead of schedule
