How to add satellites to Traxis? | SatelliteGuys.US
Kikar
22
The title pretty much says it I have a traxis and was wondering if anyone might know how to add birds that are not preprogrammed into it.
I don't have a Traxis setup in front of me, but on some receivers the list of satellites cant be edited, so you have to use another satellites name, for example at 127w G13/Horizons I use G9 as that position as thats the old name for that slot, its not ideal but its an easy work around, if you can upgrade the software it may include any new satellites that are launched.
If there is any C-Band satellites on it and if you dont have a C-Band, use those.
I used a couple of C-Band satellites on my Pansat for SBS6 & H1
