Guys,
First this a great forum. Finding it on the web may be a problem.
I found this site on a whim. Meaning I did a search for Voom and ESPN and on the 3rd page of the search I got to this site.
I took a look at your source HTML and it does not seem to have any meta-tag (keywords) that search engines use to find websites.
I would have loved to find this site before I bought my service but you guys did not come up on the search engine radar.
I suggest adding some meta-tags to your home page.
A starting list could be Satellite, Dish, Direct, TV, Voom, High Definition, HD, HDTV, service, DBS, comparison, price, cost, programming, forum, help, echostar, Over, air, OTA, resolution, 1080i, 720p, DVI, 480p, component etc...
Just a thought.
Also would you be able to put this document in the form of a web page http://www.satelliteguys.us/attachment.php?attachmentid=827 using the meta-tags above.People new to satillite and to HD are in bad need of this info.
I believe this will increase your web-page traffic considerably.
Pat
Just a thought.
Pat
