How to use USALS on Invacom QPolar | SatelliteGuys.US
weighman
16
How do I use the USALS to move the motor on the Invacom Quad Polar? I have set things up fine on the linear side, but if I want to use the circular and move the dish, how do I wire this up so both L and C move the dish???
As Qwert said, cable from your receiver to the motor FIRST. Then from the motor lnbf input to a Diseqc switch or a 22khz switch. Then cable from 2 inputs of the switch to an L output and a C output of the Invacom lnbf. That's the long way of saying it, I know .
Quad Polar and Motor
Thanks guys.
I set it up and it works great!
I get all sats between 91 and 148 now. Im in an apartment building so I cant get and LOS past these points. But its working grrrrrreat!
Interesting....
Would this be the same wiring hierarchy if using a C-band motor/mount, Primestar 1m, fitted with the Invacom 031 CLCL LNB.....driving with a V-Box?
n00b diseqc config question
Quad LNB
