Here are the steps.
1. Menu - Search - Keyword
2. Type IAMANEDGECUTTER
3. Continue
4. Select ALL in category
5. Done
6. On the front panel of receiver, select INFO and MENU at the same time.
You should see your options
On the front panel thats were I'm going wrong. Thank you
The HR20-700 is the testbed for all D* Cutting Edge beta releases. If they get it working right on HR20-700, they then release to other models.I have a D11 receiver, and can't get the IAMANEDGECUTTER function to work. Does it only work on the HR20?
I just want to be able to press Guide once to get to the channel list, instead of pressing twice to bypass category sort. Is there a different backdoor on the D11?
Also, I just started my Directv service in April (SD, no DVR), and got two D11 (I had no choice), but it seems like everyone on these forums have an HR20 - did I get an older model than I should have? Does anyone know if it's easy / free to request a newer model?
Limited time offer
