Hr20 w/ Black recordings | SatelliteGuys.US
rmmrph
92
I have an interesting problem. A show that my wife records daily via OTA has not been recording properly for past 4 days. The channel signal is good, I watched it just prior to the recording today. When you attempt to play the recorded show back, the screen goes black with just the progress bar at the bottom and does not do anything. I scheduled and successfully recorded a hockey game on the same channel yesterday. Is this possibly some type of corruption in the series recording list? :confused:
Is it only one OTA channel that does this?
Did you manually select the hockey game for recording?
I would rerun OTA setup so that the unit has the correct OTA channel mapping. Then redo the faulty series link.
Yes it was only the one channel that did that. I selected the hockey game from the guide to record. I removed the series recording and then selected it again, and is working again now. thanks for the reply though.
D* what a change...For the Better
Looking for 99 & 103 w/o $$$$$ signal finder !
