HR21-700 playback freezes | SatelliteGuys.US
RogerD
33
I have HR21-700 for a couple weeks now. It freezes one or two seconds into a playback frequently. When it happens, you can fix it by resetting the unit. Reseting the unit takes many minutes and it stops your recording. Thus it is not a good solution. The problem will come back again within an hour or longer than that. I could not find a pattern for it to be reproduced. Also when this happens, changing channels becomes very slow, taking more than 6 seconds. Does anyone see the same problem? If you do, do you know a fix for it? There are discussions about this in DBSTALK below.
HR21-700 Playback Freeze - DBSTalk.Com
Sounds like a widespread software problem.
You may want to watch for a CE (beta test) software release on Friday/Saturday nights.
There are some CEs tonight, but none for the HR21. Hopefully next week.
After glancing through the thread you linked, doesn't look like a fix yet. D* is very aggressive in fixing this kind of stuff, hopefully soon.
There is a HR21 CE release tonight only.
You may want to download it and see if it helps your problem.
Hope this gets to you in time :)
11pm - 2am 1/14/08
Will my receiver download it automatically tonight or I need to push it myself? If I need to push it myself, how do I do it? Sorry that I came from Dish and is not very familiar with this DVR yet. Thanks!
installation questions
Any MPEG 4 channel list?
