HR24 & HR22 MVR Issues | SatelliteGuys.US
petsheep
69
Chicago
I'm lost...
I previously had an HR22 w/DECA adapter and a H25 setup without any MVR issues. I've now introduced an HR24 and removed the H25. I cannot get MVR to work on the HR24. When I do the network setup, it keeps telling me no connection found. Also, I don't understand why it keeps saying to connect an Ethernet wire. I have a SWM setup. I thought DECA is built into the box? What am I doing wrong here. I've tired everything. HR22 is working fine (for what I can tell without actually using MVR) since it's connected to the network. Only thing I have plugged into the HR24 is one coax cable. Please help. Thank you.
Did you power the box with the swm coax connected and no ethernet connected?
What kind of splitter is being used? Have you tried swapping boxes around and see if the problem follows the box or if its the coax connection?
Sent from my C64 w/Epyx FastLoad cartridge
Freaking DTV. I restarted the box and everything works now. Sigh. Thanks for the post digiblur.
New House Coax Question...
Help with planning a small MDU
