HR2x CE Release 9/25 v.35B | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,047
452
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
Window of opportunity to download:
Friday, September 25, 2009 11:00PM - 2:30AM ET
Saturday, September 26, 2009 11:00PM - 2:30AMET
Risk Level for this Download: Very High Risk
New features
New Playlist and Playlist sorting persistence
DIRECTV On DEMAND program detail screen facelift
Improved/Updated
Under the hood
Notes
All MRV clients/servers must be 0x353 or higher
You will lose your guide cache when reverting from CE to national
Please do not report guide sluggish issues within the first 24 hours of download
When reporting issues with 1080p, please include the TV resolution
information reported from the Miscellaneous Options screen as well as
your TV model
Multi-Room-Video activated with keyword "BRINGMRVBACK", disabled with "LOSEMRV"
Previous Release Information:
New features
(0x034D) - Left Menu appearance
(0x034D) - Support for Linksys WET610N Wireless Adapter
(0x353/0x354) - MRV is back!
Improved/Updated
(0x034D)
Playlist touch ups
Prioritizer renamed "Series Manager"
"Rec. Once" and "Rec. Series" text now more user friendly in To Do List and Guide
In the TO DO LIST for upcoming recordings:
Rec. Once is now Episode Options
Rec. Series is now Series Options
In the TO DO LIST for programs currently recording:
Rec. Once... is now Recording...
Rec. Series... is now Series Options
In the GUIDE for non-series-link programs:
Rec. Once is now Record Once
Rec. Series is now Record Series
Under the hood
(0x0350)
Under the hood
(0x353/0x354)
Under the hood
(0x0356)
Under the hood
List cap...
Got the new software x35B and now MRV doesn't work. Get message" Cannot play DTCP content. AKE fail." (HR21-700)
Common Server problem; you may have to restart one or all MRV servers. One suggestion would be to use Directv2PC to T/S or locate the Server that needs a restart.
well thats whacky, i did the DL twice, both times it said 34c was downloading, so i went to the info screen and it says 35b and the list has that nice new view... oh well...
You must have got it the first time and not realized it.
I noticed this with last two CE's that the screen initially says it's looking for x34c but the CE actually starts loading after a delay. So it appears as if 34c will load but the CE loads instead.
Me too, Got the new software x35B and now MRV doesn't work. Get message" Cannot play DTCP content. AKE fail." (HR20-100). Restarting the boxes now
Did updates tonight for first time and MRV works using a HR21-100/H21-100.
When does this release get overwritten by the normal release?
Got x35B successfully first time on HR23-700 and R22... 435b on H21-200... All seem to be functioning normal... (have not tried anything advanced yet)
