the hr20 is a computerJust installed a Cavalry 750gb external hard drive to one of my Hr20s - it was a simple as indicated by everyone - took all of 5 minutes. However, I do have a question. The on/off switch light flickers. According to the instruction booklet, it is supposed to do that when connected to a computer but of course says nothing related to a DVR installation. Is this flickering normal?
Thanks a lot.
no problem, i give you a lot of credit for doing this,,, it is a struggle for me to keep the flashing 12:00 off of my parents VCR... btw, you mentioned brain functioning,,, what is the order of degression pertaining to loss of bodily functions?,,, I am 52 and already suffer from middle age blindness.Thanks a lot - of course it is a computer. At 82 (going on 83 shortly)- sometimes the brain doesn't function on all cylinders - think I am lucky it funtions at all.
I bought a 500GB WD drive. When I went to plug it into the receiver it would not fit. I pushed a little bit and the entire esata connector fell off into the box!
Do you need a special cable or will any Esata cable work?
It is called a type I to type I. Usually I-I on the packaging. Also make sure the packaging has eSATA to eSATA & note the lowercase "e".
If you have a Fry's nearby, there is a generic cable for 9.99 that works.
Hi, I went through like about the first 7 pages of this thread and I either missed or did not see what I was looking for. I just got my HR20-100 last week. I bought a 750GB drive and enclosure and hooked it up. Everything seems to be fine, but how do I know it is reading from the external drive? I have a SD DVR box from DirecTV and that tells me how many hours I have left. This one just shows a percentage.
Limited time offer
