Did you generate an error report for DirecTV while you were having this problem so they could see what was happening?going back to the national release fixed it.
Downloaded CE November 1 around 1:30am. Unplugged the HR22-100 November 2 around 1am because I needed to re-arrange the cables on my ups. After plugging the machine back in I noticed that one 1 hour partially viewed program apparently got deleted in the process.
I have never had a program disappear during any reboot or unplugging on my DirecTV DVRs before under any circumstance CE or standard versions.
How do you do that with a black screen in front of you?Did you generate an error report for DirecTV while you were having this problem so they could see what was happening?
I suppose I could haveYou could have tried connecting a s-video or composite video connection to see if you could get an image to get to the report function. I had to do that when testing the 1080p HDMI problems with no video.
If your setup is anything like mine, that would have been a royal pain in the you-know-what...assuming you even have extra cables laying around. The harassment from Rad is unnecessary.
May have had something to do with the time change for daylight savings ending.
I had a movie split in half on my other provider box due to the time change...
Note to self do not reboot DVRs during time change heh. Maybe that could be on a sticky of things to be cautious of?
Well, it doesn't come up too often, only 2 hours a yearMost of us are sleeping those two hours too
WOW, what a simple change that is a huge success for users like me, and will be a long-term success for D* business customers, i.e. bars, etc.
The options for 8 IR remote codes are simply 00001 through 00008. Originally, when set to the alternate set (AV1/AV2) the receiver used code 00003.
That made havoc for me using the Slingbox (which would be MUCH easier if D* could ever setup the receiver to do IR & RF simultaniously) work without special drivers.
There was a driver file made by a user for the 00003 remote codes, but the new Slingbox Pro-HD didn't work with it. The Slingbox software does, however, have built in drivers for the 00002 code (listed as the D10 remote code 2).
SO - THANK YOU DIRECTV ENGINEERS for enabling multiple IR addresses. Although a feature that will get rare use - to some users - it is HUGE!
Limited time offer
