Hmmm, don't know if I like the combined playlist, much preferred the separate list, that way somone on the other receiver can't see or delete my stuff without some effort.
I've been trying to get the OTA SD subchannels of WQED in Pittsburgh for the past couple of months, and had hoped that the "missing OTA channels" fix would cure my problem, so I downloaded this CE software. The good news, for my basic features (I haven't tried MRV, etc.) this software seems fine. The bad news: I'm still missing these channels.
The problem is described in much more detail here:
Discussion Forum
Regardless, I really appreciate this service.
-- Allen
MRV is not working on mine, I noticed on the network service tab last week when MRV Broke that was one thing that changed they had numbers in the Port fields
this week on one machine it still has the 27163 in the STB Services Port field, the other machine says "Any"
I wonder if this is what broke MRV last week and why one machine still has the numbers in it and the other does not.
I will try redownloading the CE tonight to see if that gets cleared.
A CE 99% of the time won't fix an OTA problem. Downloaders are supposed to be reviewing and reporting any bugs to the developers.
What receiver are you using? Are you using the OTA module? Are you getting good OTA signal? Is WQED broadcasting with correct PSIP data and is supplying correct data to Tribune for channel mapping and guide data? Any of those would need to be verified. This issue should probably be discussed in the regular Directv forums.
But it was supposed to fix "missing OTA channels." Was I unreasonable to try it, after I'd already pursued most of what you suggested?
To answer your questions:
Receiver: Both HR20, and HR21 w/ AM21
OTA module: on the HR21, not neede don HR20
Good signal: Yes 13-1 is clear, only 13-2, 13-3 are missing.
Correct PSIP data: Can't tell, but my Pinnacle, Pioneer, and Panasonic receivers have no problems with it. Can you recommend tools?
Tribune: According to WQED, Tribune has the correct info.
I agree that we can take this to another forum now that it's not addressed by this CE release. Either WQED-SD ch. 13 - Pittsburgh, PA - DBSTalk.Com or Discussion Forum would be fine. I'd rather not start yet another thread on this topic.
Limited time offer
