HR44 flashing lights. | SatelliteGuys.US
PremSat
3
Bensenville, IL
Tried googling but could find any info on the particular issue. All the resolution lights on my genie are flashing. I haven't noticed any issues, but does anyone know what this means?
Sent from my LG-H900 using Tapatalk
I found this for D* receivers:
"It's probably 1 of 2 problems. Most likely, your box has downloaded an update. It's waiting to reset. Hit the red reset button and let it come back up again. If it doesn't stop, reset a second time. If you reset twice in 30 minutes, it resets a lot of setting and memory and should clear up the problem.
Second, it may be something wrong with the resolution switching. If you have "Native" on, and the box can't figure out what resolution it's supposed to be, these lights will flash. Set it to native off and lock it to 1080 and it won't do this."
https://www.reddit.com/r/DirecTV/comments/2ugqzg/why_are_these_5_lights_blinking_on_my_cable_box/
4K channels are on
More DIRECTV 4K Information
