HTS actuator help | SatelliteGuys.US
HTS actuator help
gabewinches
20
7
06611
I found a 10 foot dish a few months back and was looking at the actuator, I have sprayed pb blaster multiple times and can't get it to budge. I am having trouble taking it apart, and it seems there is only one bolt to do so, and no sockets fit in the small opening. Is this even repairable, or should I just buy a new actuator
If a standard or metric deep well socket won't get in there then it must require a special tool. That would be my guess.
since that light colored bearing securing device is not secured by the bolt , holding the motor to the pipe , it might be possible to push the thinner pipe out by stamping it vertical on a solid wooden block
In the photo, that looks like a spanner hole to me. That bearing/bushing holder might just thread out of the tube if you can apply the right rotational torque to it.
Sent from my Commodore P.E.T. using the SatelliteGuys app!
Skytunes Earth Stations BUD
