Hughes = daily limit (only have to wait a day to be able to use your service as usual after your bandwidth usage is up).
WildBlue = monthly lmit (have to wait the rest of the month once you use up the amount of bandwith usage allowed for the month). This is good if you have large downloads just once in a while that would put you over the daily limit but do not use it much beyond that on a limited basis.
I also know of several that have switches from WildBlue to Hughes due to this. Another reason I prefer Hughes is due to the fact that you have unlimited bandwidth usage between 2 am and 7 am that does not count towards your daily limit. This daily limit is refered to as FAP (Fair Access Policy).
If theres a cell tower anywhere near you, you may want to consider mobile broadband.
Millenicom and other resellers have unlimited plans in many areas that have no fap.
the only thing i can get is wireless internet and its not from a cell tower its some other kind of wireless. the antenna outside looks like an off air analog antenna but its small and it points towards a tower. thats what i have now but its not very reliable it cuts off all the time
That outside antenna that you have to receive the wireless internet signal is a yagi antenna which is very directional. Did you notice good service in the winter and poorer signal when spring came with the tree leaf growth? If so then it means that your signal degraded due to the trees growing out. Since that particular antenna is more directional then it would not take much to knock the antenna alignment.
It may not even be a signal issue, it could be other things such as oversubscribing (not enough bandwidth to handle all of the customers / traffic), interference (can be caused by other providers in the area or in a city area - lots of routers, phones, etc).
jhall2005 said:which is better?
Whereas the points made in your comparison remain valid, this assumption is incorrect. Wildblue has been a Ka-band provider from the git-go. They've never had any Ku-band options - ever.... and wildblue customers are forced to use the KU band systems.
grohgreg said:Whereas the points made in your comparison remain valid, this assumption is incorrect. Wildblue has been a Ka-band provider from the git-go. They've never had any Ku-band options - ever.
//greg//
Wouldn't be able to tell as their ka operates just like ku- slow, unreliable and oversubscribed.
oldford said:With all due respect-
Speed, reliability and number of subscribers are all independant of frequency.
Regards, Eric
Limited time offer
