yeah the echo ones will say 11250
C-Band sats are 5150
Nevermind figured out the blind scan feature neat!! I must say there is a bit of a learning curve to the geosat dsr 200 but I'm getting the hang of it.
If you are using Dishpro LNBFs and 61.5 is connected to the input port of the main 110/119 LNBF, set the LNB type to DishPro and DiSEqQ to 3. If you highlight LNB in the Search Menu, press OK then scroll up you will find to Dishpro settings, Dishpro and Dishpro FSS. With your system, set to Dishpro.
The DiSEqC switch settings control which LNBF is directed to your receiver. DiSEqC 1 is 119, DiSEqC 2 is 110, DiSEqC 3 is the input port (which is 61.5 in your system).
Not sure if DiSEqC 1.1 is supported by the Dishpro switches. You could experiment and turn off the DiSEqC port switching and assign the DiSEqC 1.1 port selections instead. No damage will occur, just might not work....
Please let us know!
I noticed on one of the birds during the blindscan (can't remember which one at the moment) would only scan the Horiz polarity and not vert even though the blindscan setting was set for all polarities. Any thoughts on that one?
Fat signals like the Dish Network transponders are easily found with even the 10MHz setting. Skinny SCPC signals on other satellites might not be found unless 2MHz steps are selected. BIG difference in the time it takes to scan!Here's a question regarding blindscan setting what is the best setting for the freq spacing of the scan? I use the default 4 mhz setting would 2 be a better choice?
If it's like every other receiver I've seen, the loop out only outputs the transponder you're tuned to. Not a demodulated version like back in the 70MHz days, mind you, but nevertheless only the transponder you're tuned to. So the Dish receiver wouldn't work, at least not in any user-friendly way.
You would it think it would be just a "pass-through" to the lnb.
The master receiver (GEOSATpro) selects the polarity and the DiSEqC switch setting if powered ON. All channels are on the horizontal polarity with your Dishpro system, so that is not an issue. The slave receiver (222) would only be able to receive channels from the satellite selected by the master receiver. The Loop Out feature would work fine if only one satellite was connected. Since your system requires DiSEqC switching between three satellites it is not possible for the slave receiver to control the satellite selection between the three satellites if the feed is looped out of the master receiver and the master receiver is powered ON.
You may update firmware via USB and also modify the satellite, transponder and channel list with the Channel Master channel editing software (Import and export as a CNX file type). Recent Firmware and instructions are available at: http://satelliteav.com/portal/33/documents/DSR100c_DSR200c_Firmware_Loader_Guide.zip
Once you have your dish set-up you can download the latest firmware and satellite / transponder list manually or automatically via satellite. Currently we are running identical firmware updates on Galaxy 19 transponder frequencies 12115 and 11842. A firmware update takes approximately 4 minutes and satellite / transponder updates approximately 1 minute.
Limited time offer
