ia5 and 101w | SatelliteGuys.US
ia5 and 101w
should work just fine. I did it once with the newer quad LNB
The LNB on the right will be for 97 and the one on the left is for 101 (they're opposite because of the bounce off the dish)
would i keep my dish skewed or will i put it back to level, also iceberg so when i go into setup the reciver, (behind the dish)left one whick is on 97 now will be 101, is this correct, and which one do i line up first?? thanks man
yes you will need to skew the dish. Thats the only way to get 2 satellites at once :)
Yes. The left one will be 101 and the right one is 97
I'm a new guy! help me hack
TP Freqs - I'm Confused
