If you own a Phillips SRU5107 universal learning remote | SatelliteGuys.US
Conky
430
54
SW Ontario
code 0256 will control your MicroHD(at least the basic functions). That is a code for Coolsat so it's possible if you have a Coolsat remote lying around it might control it as well
good to know
The coolsat 4/5/6000 remote wont interfere with the Micro...I have both in the entertainment center (a 5000) and they play nice
Couldn't believe that Philips is the remote I've been using! Good info! Hadn't done the "learning" yet on the new MHD remote yet into it!
I do find the MHD is a little tough to control from about a 45 degree angle out in my RV with its original remote.
Been thinking of trying a clear "bubble" of some kind over the remote window on the MHD to see if that helps capture the signals a little easier on the sides. Not sure if it would help. Not sure what could be used. Small inconvenience given all the pluses of the new receiver!
how to setup Disque switch on MicroHD
Setup/USALS Issue?
