Thanks for the reply. I want to get a tuner because I want to have an IPTV server (just for my family and I) so I can watch FTA channels away from home. Are there any receivers that also double as an IPTV server and are they any good? If so, I'll probably get one of those instead of a PCIe card.I would not recommend one to a newbie. There are some that work well, but software can have a very steep learning curve. You will end up with a lot of frustration, especially since you don't know how things are supposed to act. Also good to have a basic receiver to throw in line to make sure your dish and such is set correctly. That way you know it is a matter of get the card drivers working and software working.
I also don't recommend a USB tuner. I would build a small HTPC(Home Theater Personal Computer) and get a tuner that is PCI-e card.
I would expect that this will become more important as UHD content catches on (assuming it ever does).I would build a small HTPC(Home Theater Personal Computer) and get a tuner that is PCI-e card.
PC tuners can be a challenge. I never knew how much because I found out about FTA through a DVBS tuner. I found one in a computer surplus store cheap and never heard of doing FTA satellite on a computer or an STB. I fell right into it (backwards I think) and became hookedThanks for the reply. I want to get a tuner because I want to have an IPTV server (just for my family and I) so I can watch FTA channels away from home. Are there any receivers that also double as an IPTV server and are they any good? If so, I'll probably get one of those instead of a PCIe card.
Setting up a remote can be the challenge with a Slingbox
Limited time offer
