In-line Amp | SatelliteGuys.US
In-line Amp
ToUgHsPot
60
I need to know what is the approximate maximum distance the LNB (dish) can be from the IRD (receiver) with an IN-LINE AMP installed.
Thanks in advance for your help
RG6 loses about 12db per 100 feet.
Amplifiers up about 20db, tops, thus adding about 180 feet of length to maintain good signal strength.
I would say 300 feet would be your absolute maximum, but only if the dish has a good signal to begin with. If it gets a lousy signal from the satellites, you'll need it closer.
H
R15 with $100 rebate
YES Network/Local Channels
